Hey
I have been thinking here, and haven´t found any information on my "problem". I got an ACE engine, with 10.8 compression, but people have been measuring, and have said, that it is actually 10.5. So my concern is, what kind of compression I end up If I buy Wössner 8.0:1 pistons, is it 8.0:1 or is it 7.7:1 ? If you look at the Wiseco 9.0:1 pistons, it says -11cc, that would actually make 8.7:1?
Hope someone can enlighten me!
Wiseco -11cc (supposed to be 9.0:1) And calculating with engine/wiseco specs., I get 8.56:1 -compression ratio.
So what is right?
I have done some calculations with given specs on JE, Wiseco, Wössner, and come up with 0.3-0.4 lower compression.
So what is right?
. I thought the OEM is 83mm, I got a few, I should measure. And +0.180, means that it is below deck.
