Identify rs2 / s2 chips
  • vidar skotheim
    • Apr 2005
    • 566
    • Country: Norway
    I have some chips that was told was for s2 ecu and s2 maf and rs2 injectors , in the vag com text it says
    8A0 907 551 B and 2.2R5 Motor.RHV RS2 D03 .
  • blackS2
    • Apr 2010
    • 455
    Basic program should be RS2 but whats real inside you have to read them out...
    [__]=oooo=[__]
      Fit them and VAG com the ECU to see what the description is.
      • vidar skotheim
        • Apr 2005
        • 566
        • Country: Norway
        I am not so into read out program , buth tink it is strange if these are for s2 ecu / maf ..
        • vidar skotheim
          • Apr 2005
          • 566
          • Country: Norway
          I allready wrote what comes up with vag com ..
          • blackS2
            • Apr 2010
            • 455
            must not be strage... MAF is no point because 99% equal...
            if they are for S2 ECU, the load/fuel calculation must be modified in data...
            I can read them out for you if you want...
            [__]=oooo=[__]
            • vidar skotheim
              • Apr 2005
              • 566
              • Country: Norway
              There is big difference in load with s2 ore rs2 maf , also the wide band say big difference in the maf .. so that could not be correct .
              if i put a s2 maf on a rs2 ecu the wide band dorps from say 13.5 to 11.5
              • vidar skotheim
                • Apr 2005
                • 566
                • Country: Norway
                load with s2 maf on the rs2 is close to 50% , with rs2 maf arround 30%
                • blackS2
                  • Apr 2010
                  • 455
                  THIS sounds strange to me
                  [__]=oooo=[__]
                  • vidar skotheim
                    • Apr 2005
                    • 566
                    • Country: Norway
                    Tested lot og different ones . Lot of difference ,as it should . If not the rs2 would not be abel to follow on more power .
                    • Colesy
                      • Feb 2009
                      • 2980
                      I thought it was accepted that electronically the S2 MAF and RS2 were the same. They do loose calibration over time though so an older MAF will appear different to a new one. This was covered partly here:
                      Lots of info here too:
                      • blackS2
                        • Apr 2010
                        • 455
                        so I do
                        [__]=oooo=[__]
                        • vidar skotheim
                          • Apr 2005
                          • 566
                          • Country: Norway
                          Well . I have tested many different ones and they al give the same result ,also after driving a few days .. when use a s2 on rs2 it gives a lot to much on partly throtel . What is writen on net i dont care about . My wide band i thrust more ..
                          • blackS2
                            • Apr 2010
                            • 455
                            What is writen on net i dont care about ..
                            so why do you ask somebody here on the internet
                            sorry
                            [__]=oooo=[__]
                            • vidar skotheim
                              • Apr 2005
                              • 566
                              • Country: Norway
                              I asking about identyfing chips , not about using different MAF .
