Does anyone use nos
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    Does anyone use nos
    Does anyone run nos is it good does it give extra performance as it states
  • mac2226
    • Jun 2008
    • 1289
    Yes I've used it in past but the system i used was wizard of nos with different controllers mini max,pro max,extreme max all have different capability and setup it can get addictive so be prepared for regular refills but yes it does work if setup correctly and i used a blanket to keep good pressure in a bottle make sure your clutch is upto job and go a couple grade colder spark plugs and be careful with jumping up jet sizes as fuelling needs to be correct may be wise to go to a dyno and see what it's running like so you don't damage engine all best Michael
    • nip
      • Apr 2006
      • 1786
      Cheers Michael, I can get a kit made up for pennies off a friend, I won't use it much but as you say it's addictive il keep you posted mate cheers for the advice 👍
