Help 2.5tdi Ael Fuel Pump Timing
  • Pauliusb2
    • Dec 2014
    • 361
    HI I NEED HELP WITH MY 1996 AEL 2.5TDI A6.
    THE CAR WAS STANDING FOR MORE THEN A YEAR AND WHEN I BOUGHT IT ITS HARD TO START IT UP AND ONES ITS FIRED UP LOADS OF BLUE/WHITE SMOKE COMES OUT AND IT SMOKES UNTIL IT GETS WARM....
    I DONE A LEAK TEST ON INJECTORS AND ONE WAS FAULTY SO I CHANGED IT AND NOW ITS FINE BUT STILL HARD TO START AND SMOKES THE SAME....
    MAYBE THE TIMING NEEDS CHANGING?IF YES HOW DO I DO IT?
    ANY IDEA?
  • Thuppu
    • 4115
    Haha, I will also need to do this also on my AEL, only difference is that it's sitting in a Volvo. The head has been off, and I have no clue how to setup the pump timing.
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      If I recall correctly then via the belt in the back of the engine. Get everything into marks and align the pump. Strap the back belt on it and start it. Connect VCDS (or VAG-COM) and you can see the injection timing. I don't remember the degrees, but you can find them. After that it's a process of rinse and repeat - belt off, correct pump pulley, belt on, start, check timing, if correct then profit, if not, do it again.
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        At tdc. the pump plunger has to be at 0.25mm
        I, usualy, make them at a little more advance...so..0.30mm
        Is tricky...untill you find the right spot.
        You need an dial gauge.
        Goodluck!
        • Pauliusb2
          • Dec 2014
          • 361
          Sounds like VCDS is easyest option then,but i heard that even if the timing is spot on these engines not allways run,the timing needs to be earlyer...
          • morgenlatte
            • Jan 2013
            • 101
            • Country: Austria
            i also have it at about 0,28mm at TDC.. runs nice, starts nice..
            1990 Audi 100 2.2 Turbo Quattro with VEMS, K24 2480, ported and milled 10v head
            • AndyP
              • 6049
              You really need VCDS to check the timing, and it needs to be the full version not the free-ware version. You will get a graph with 3 lines on, I always run mine advanced right up to the green line.
              Starts first touch of the key
              • Pauliusb2
                • Dec 2014
                • 361
                Maybe it will sound stupid but anyone can explain more how to do it manualy?
                • Pauliusb2
                  • Dec 2014
                  • 361
                  Or anyone in uk could do it for me with vcds?
                  • Thuppu
                    • 4115
                    Hmm, I don't think VAG-COM will work with my Volvo..?
                    • domas
                      • Oct 2014
                      • 307
                      • Country: Lithuania
                      just use vag com and use tdi timing graph.
                      no need to remove the belt, just loosen the pulley and turn it
                      • Pauliusb2
                        • Dec 2014
                        • 361
                        Thanks all car is going to garage tommorow to get it timed up
