advice for cams with solid lifters and opinion
  • as2nerka
    • 149
    • Home: Sweden
    what opinion if I will use catcams
    in 293' 12.75mm
    ex 279' 12.00mm or 279' 11.45mm
    witch combination is better , or maybe somebody will give good advice?
  • Audi_CQ
    • 940
    • Country: Norway
    For what use. Road or track? 293 intake sounds a bit over the top even for track use.
    I've got custom mechanical Cat Cams and they are only 256 degrees. 2.5 running E85. About 600@wheels
    • as2nerka
      • 149
      • Home: Sweden
      For road. Now in the engine 264' 10.6mm shrick cams hydro and 600hp e85 .
      • Audi_CQ
        • 940
        • Country: Norway
        For road use I would have used the Shrick cams Why change?
        • Quattronaut
          • May 2013
          • 273
          I think the Schrick ones are for hydros...he wants mechanical head. 293 seems to be veeeery much, you gotta rev real high to use them. PK got a set of 10,4 lift that is grinded from stock ones, so they should have degrees near to stock ones. He recommends them for steet use up to 500-600 hp with mechanical lifters and 8000rpm. His other set is made of 7A cams with far more lift an bit sharper- they kick in later, but give much more power in upper revs.
