hey guys. ive been looking for a gearbox upgrade for my audi 200 20v. some stronger gears to withstand a substantial amount of horsepower. im going to run around 700 / 800 bhp on e85. i havent found gearbox upgrade gears for my speed stock 200 20v tranny. (i think its 01E ? ) anyone have any tips or is there a factory 6 speed gearbox that can fit without heavy mods ?
gearbox upgrade 200 20v
i believe the strongest 01e gearbox is one of an rs4 b5 typ(380hp) code FDP
many guys also use the s4 b5(265hp) gearbox code DSY
i have driven with 500hp and a urs4 gearbox (code CBL) without problems but i never make hard launches on the roadaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injection -
016 Workshop Manual
A US bound 1991 200 20VT was equipped with a 5 spd ADZ transmission. The ADZ was a 016 not 01E.
You might be interested in this: http://www.t85q.com/Audi100_GboxManual.html
016 shift knob/pattern:
01E shift pattern/knob:
Interesting!! I have 01E gearbox i want to use in my 200... But the supports will be the chalenge. I will fabricate them...if there are other alternatives... Please let me know.
Goodluck!
Eugen
Ahhh... About gear shift lever... I bought the 6 speed V8 lever with brackrt.. Etc. New from Audi.Comment
About driveshafts... Yes. But the propshaft lenght is the same. The boxes are the same lenght.Comment
AEM W/M injectionComment
What i found during my searches.... The driveshafts on 200 are equal lenght left and right.hey guys. ive been looking for a gearbox upgrade for my audi 200 20v. some stronger gears to withstand a substantial amount of horsepower. im going to run around 700 / 800 bhp on e85. i havent found gearbox upgrade gears for my speed stock 200 20v tranny. (i think its 01E ? ) anyone have any tips or is there a factory 6 speed gearbox that can fit without heavy mods ?
On 016 6 speed V8 are 1 shorter and 1 longer but, the added lenght is the pretty much the same.... Is like the 01E box has the front diff moved sideways few cm as the 016 box.
I will make all the propper measurements with both boxes next to eachother.
The lenght issue does concern me...
You are right!
The 6 speed box is shorter with aprox 2cm.
Not good....
Custom mounts, propshaft spacer...
