Is there an easy way to tell whether a chip set is designed for a 2.5 or 3 bar map sensor when you view the file in an Hex editor, for example a certain value at a certain address.
Motronic Map Sensor value
94 UrS4 V8 6 spd manual avant -
With my RS2 based software, yes.
I have a specific constant that I put there to identify which it is, allowing my map editor to represent the pressures correctly upon opening.
Any other software - no, you will have to open the maps and look what makes sense.Comment
