Tina Turner.... Steamy windows.
  • raccabuda
    • Aug 2007
    • 157
    I probably know the answer already but just to confirm.
    My 94 UrS6 steams the cabin up when I have the heater and blower on at the same time , to the point where it is borderline unsafe to use.
    I put it on cold blow today and it cleared the screen but it was a bit nippy!
    Is my heater matrix borked or is there somthing else I need to look at? The blower fan needs to be changed so do I do it 2 for 1 and if so have you got any tips to doing the matrix and fan?
    C4 UrS Coolant leaks and fan and heater core DIYs
    Potential C4 UrS coolant leaks: http://forums.quattroworld.com/s4s6/msgs/325087.phtml
    C4 HVAC fan replacement DIY: http://12v.org/urs/HVACblowerRR.pdf
    C4 Heater core (matrix) replacement DIY (the best I know of): http://12v.org/urs/C4UrSHeaterCoreRe...ntDIY_Rev1.pdf
    • AndyP
      • 6049
      Mine used to steam up badly, turned out the re-circ flap was stuck shut, once I fixed that it's been fine since
      • raccabuda
        • Aug 2007
        • 157
        Thanks lads, that's next weekend sorted then!
