Glasgow ish favour - are you running new coils?
  • als2
    • Jul 2009
    • 809
    Hi guys, im having a bit of a mare fitting new style coil packs. Car runs fine but swap to new coild and she wont fire.
    Checked everything, all the pins etc and all good but no spark so somethings amiss!!
    Anybody local thats converted to new coils that wouldnt mind swapping a few parts so we can identify whats up?? Happy to come to you or you welcome here in my warm heated lit garage!!! Lol. Based in motherwell
    Cheers in advance guys and goes without saying a few beers and a hand with anything for your troubles!!
    Al
  • martinws
    • Oct 2008
    • 917
    By 'new coils', do you mean standard coils or tfsi ones?
    • als2
      • Jul 2009
      • 809
      Tfsi ones fella. Should have made that clear.
      • Rikki Kitto
        • Feb 2010
        • 6276
        Sounds obvious but have you checked continuity with wiring plugs etc
        • martinws
          • Oct 2008
          • 917
          Also check that the boots are trimmed if they are those ones to let the coil connect to the plug. I have a full set of stock coils but am in the process of converting to vems so can't help with part I don't think.
          • als2
            • Jul 2009
            • 809
            All wiring plugs checked etc all good.
            When you say trim the boots do you mean the top part of a bit off the bottom ?? Thought you didnt need to trim them anyways??
            • martinws
              • Oct 2008
              • 917
              I think depending on which coil you use, the top needs a wee trim so the plug contacts the coil when pushed in. It's been a while since I read any info on the conversation so I can't remember exactly what or if I'm talking S@#t.
              • als2
                • Jul 2009
                • 809
                You may be talking s*#t lol i trimmed one back to make sure it was a good fit etc and turned it over, with a plug in it and no spark. ****** lol
                  Why are you posting the same problem in two different threads? This forum has the "bump" feature that brings the old thread to the front when you add a new post to the thread.
                  In the old thread I posted some info but never got a response from you.
                  "Did you attach both grounds of the new harness to the appropriate points (back of the cam cover and the intake manifold).
                  Did you install the harness connectors correctly? It is possible that you swapped them.
                  Should be based on these diagrams:
                  Your old POS wiring diagram to figure out the ECU harness colours for 1-3 and 4-5 (pull the boots back):
                  1.8T coil pack wiring for an AAN (make the required ABY translations):
                    The original 1.8T shorter coilpacks need some trimming of the hard plastic and the rubber seal to fit down properly on the plugs. IME, the later taller coil packs need no trimming. I am running the read 115Es now and they went in with no trimming whatsoever.
                    • als2
                      • Jul 2009
                      • 809
                      Hey fella, sorry didn't mean to cause offense.. Reason for the second post was looking for some local physical help and I thought a specific post would yield more success. And in reply to your information, many thanks, it allowed me to check the pins and wire colours etc along with the earth, so thank you.
                      I have the later 2.0tfsi coils so I'm assuming I don't need to trim. Thanks for your input.
