3b Crank pulley diameter
  • etsola
    • Feb 2015
    • 285
    Nice design. I like it !
    • blackS2
      • Apr 2010
      • 455
      Originally posted by Thuppu
      Black, really good pics, thanks.
      Can someone confirm that is the 3B/7A damper "gray"(middle section) part solid with the hub?
      from partscat, there is no 3B/7A damper...
      there is a
      7A/NM damper = 034 105 251 C
      3B damper = 034 105 251 G
      a 7A damper looks more like the ABY
      [__]=oooo=[__]
      • Thuppu
        • 4115
        Haha ok, great. All have different dampers. Well I have now made up trigger wheels for AAN, ABY and 3B.
        • blackS2
          • Apr 2010
          • 455
          But from the measurements of the ABY damper, I cant imagine to weld something to the 6.8mm thin center wall without destroying the rubber
          [__]=oooo=[__]
          • etsola
            • Feb 2015
            • 285
            Hey Thuppu - Just a question, at what degrees BTDC have you installed your sensor ? i.e. how many teeth BTDC ? 20, 25 ?
            • Thuppu
              • 4115
              MAG weld small spots with high current, only few and let it cool.
              I'm using stock triggers. Can't it be adjusted from the ecu software? I think for example in VEMS software you can put it anywhere you wan't and then just adjust it.
              • etsola
                • Feb 2015
                • 285
                Received very quickly and very satisfied with the build. Looking forward to install it !!
                Thanks Thomas
                • etsola
                  • Feb 2015
                  • 285
                  I'll be installing Megasquirt, I think it needs a minimum of teeth BTDC for it to be able to read it ... I'll look into it myself
                  Any source for a cheaper than 034 1.9 bar WG spring ?
                  • taren
                    • Apr 2016
                    • 5
                    • Home: Estonia Current: United Kingdom
                    #39
                    Hi I have got pulley for aan with 60-2.
