Hi Guys!
I'll be finally assembling back the stuff in the engine bay very soon and wanted to ask general tips about priming these 5-pots, as it seems to differ from engine to engine. I want the start to be as perfect as possible, without any hiccups. The big question is how to get the oil flowing around. Methods I've heard are these:
1. Just use the starter, with ignition/injectors disconnected and do short crank bursts for around 20 minutes.
2. Stick it in 5th gear and strap it to another car. Start pulling, give the engine around 1000 rpm and the oil should be in the pump.
3. Use a syringe to fill the pump from the oil filter mounting holes on the side of the block.
Are these legit? If yes, then what would be the best? Does the pump suck in oil if it's dry?
Afterwards, the first 1000km are the "drive-in" period of very light loads and stuff. How does the oil change happen - pour it in, start it, heat it up to 90 degrees and then change or pour it in, drive 1000km and then change?
Thanks for any information you might bestow upon me.
Exactly this. After a couple of 10 second blasts on the starter I had 5 bar oil pressure just off the starter motor. Packing the oil pump with Vaseline is the most important part.
