S4 oil cooler on aby?
  • bluequattro
    • 2960
    Bust my cooler driving on ramp too fast(car failed test so I was peed off!)
    Is s4 aan cooler same fittings? Found one in my garden
    Originally posted by bluequattro
    Bust my cooler driving on ramp too fast(car failed test so I was peed off!) Is s4 aan cooler same fittings? Found one in my garden
    I understand that you were mad but doing damage to the car in your anger doesn't make any sense. You need some anger management. Sorry.
    (obligatory Uncle Dave comment )
    As for the oil cooler. The UrS4/S6 cooler in PN 034117021B which shows up as the oil cooler on C3 turbos as well 1985 and up. But no B3s or B4s.
    The 3B oil cooler (Item 1 below) is PN 113117021X and was also used on C3 turbos 1982-84 and many others including some VWs. Check the extensive list by clicking on the (i) icon here: http://audi.7zap.com/en/rdw/audi+cou.../117-117020/#1
    The ABY cooler(Item 25 below and in the link above) is PN 034117021D as is exclusive to the S2 ABYs and the RS2.
    • mike74
      • Apr 2014
      • 615
      Dave, it could've been a lot worse!
      • bluequattro
        • 2960
        Lol. Failed on small stuff but most annoying was tyres catching bodywork.
        Been lowered too much n big tyres fitted- not by me either!
        May just pinch the cooler from the s2 I had yesterday for breaking, just thought as s4 one already off it'd save time
        • A1QSHIP
          • Aug 2004
          • 975
          The fittings are oriented differently on the S4/6 oil cooler than on the RS2, S2/Avant, S2. On the C4 chassis one of the cooler fittings faces forward & one faces rearward.
          Chris
          "Nulla tenaci invia est via"
