Does anyone have a pic of the fuel lines on a rhd aby coupe? In particular where the hardlines connect to the braided hoses going out to the fuel rail. Had a good search but cant find a clear pic.
Tom they should both go through the rubber retainer and bend 90deg downwards. Someone has cut yours, probably kinked the pipe trying to remove it.
Couple of pics of mine to give you the idea - not OEM but very similar and marry up just nicely with the OEM ABY braided lines
