Disconnecting Lambda !
  • Faheemo
    • Feb 2005
    • 544
    • Country: South Africa
    Pulling the Plug on Mr Lambda ??
    I Currently have the Hunting Idle and High Consumption Syndrome, so I Guess it's the
    Lambda Sensor thats playing up.(From searching the forum, Thanks)
    Before Sourcing a new one I recall a quick fix that was done on my previous car, a Golf VR6.
    The symptoms where quite the same except the idle was alright.
    The mechanic Cleared the ECU Faults with his plug in Computer then Pulled the Plug on the lambda and left it disconnected.
    Worked Perfectly Therafter...
    Any ideas if this would work on a S2. ??
    Any consequences cause i cant think of any !!
    S2 Coupe fully built.
    10.9 1/4mile 0-100 in 3.5secs
    Precision 6262 turbo
    The Green Monster
    The hunting idle, will be the idle stabilisation valve, probably needs a good cleaning with WD40.
    Also i'd clean the MAF with IPA before changing the Lambda IMHO
    You'll be annoyed if you parted with alot of money for something you didnt need.
    Give them a whirl, if it doesn't work then look at Lambda
    • Faheemo
      • Feb 2005
      • 544
      Aye, Will Try this before Replacing Lamda,
      Just found out the cost of a lamda from Audi SA.!!
      R1773.00 thats about +- 170 Pounds is this correct ??
      Bosch SA Dont keep em ...
      The Green Monster
      • jade
        • Jan 2005
        • 1811
        No vag have them for 78.48 + vat
        JADE
        RS 2 580HP
        • QuattroFever
          • May 2006
          • 1360
          can the lambda cause hunting idle as well?
          Volcano ABY coupe
          Ant
          • dan_b
            • Sep 2003
            • 3670
            the lambda more often causes a rev hunting whilst driving at constant throttle and a hesitation on/off throttle, but it could also cause it at tick-over for the same reason: the car can't properly measure the mixture.
            • s2driveruk
              • 12696
              yep agreed and I wouldnt part with £170 for one either - try a good boche dealer and get them to send it to you, I think mine was £55 + vat see here:
              1992 3b S2 Coupe
              • iain1067
                • 984
                A decent motor factors may be able to help it's a common 3 wire sensor, used on many fords etc etc, i would suggest you also buy the right tool for undoing this as they are usually in very tight.
                Iain
                • Graham
                  • 1622
                  http://www.s2forum.com/forum/showthread.php?t=3808
                  Ditto, mine was £55 + the dredded, stealers are not called stealers for nothing
