hey everyone. im going to check the crank case ventilation system. im gointo to replace the valve. because my oil is being pushed out the engine and sometimes some blacl or white smoke. had some electrical probleme but got those sorted out. is there a filter or something else i can replace which can cause the problem ? i saw something like a one way bleeder valve.
crank case ventilation.
AAN/ABY/ADU Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and
Read this:
AAN/ABY/ADU Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and Links:
