Where do we start - HELP!
Have a 220bhp S2 or should we say s1.5, it runs like a Fiat Punto, Slow and gutless.
On half throttle it feels fine but on full throttle it is breathless and is slow to rev with no feeling of constant boost. It seems to be giving small pockets of power almost like it is missing but feels like boost leaking.
We have checked and replaced or swapped for a 230 S6 the following:
1. DV
2. WGFV
3. IC O ring
4. All main pipes checked
5. MAF
6. Anti Knock Sensor
7. Emissions tested (seems to rule out Lamda
8. Cats removed for straight through
9. Plugs
10. Exhaust Valves Replaced
11. ECU reset (fuses pulled/battery disconnected)
12. All conectors cleaned
13. Tried WGFV bypass but go overboost cut out
14. Turbo check, working fine
After all this the car is much the same but is now revs alittle more freely but still not S2 quick not even BMW 318 quick (thats bad). Please help, can not put up with being burned up by any more WRX,s or BMW's. Still have the S6, that is a rocket in comparison.
To top it all the dam thing is in bits, a non runner. Got a very loud knocking noise from inside the engine which got worse by the second till it sounded fatal. Checked it out and found first Tappet stuck (front of car) replaced it and still sounded the same. Now no oil pressure so replacing the oil pump (oil return valve seemed to be stuck open) but also some suspect metal/copper/brass shavings in gunge in sump.
Thought may be problem with leads or distributor but would that cause bad boost problems this bad?
Have not checked waste gate yet, not sure how to test this.
Hope you experts can help, the car has been a bad egg for a year, help get it back burning up the oppersition.
1. DV
2. WGFV
3. IC O ring
5. MAF
9. Plugs
