7a aby chamber volumes
  • S3ilver
    • Mar 2014
    • 102
    Does anyone know the standard cylinder head chamber volumes of a 7a and aby.
    ta
    I measured mine at 44.5cc
      • 4754
      I'm very interested in this,i thought or i should say assumed they were the same??
      If there not then what about all the 7a heads sitting on top of ABY and AAN blocks??!
      ABY head or 7A?? Can't remember which your using at the moment?
      • S3ilver
        • Mar 2014
        • 102
        I am assuming they will be the same casting and cr is altered by piston and bore size but will get the 7a I have measured and post result here.
          I have measured ABY, AAN and 7A all within .5cc of each other ~ all identical within manufacturing tolerances I'd say.
            • 4754
            A big sigh of relief then!
