Installing adjustable camshaft sprocket..
  • dkw_dude
    • 555
    • Country: Norway
    Hi
    How do you install an adjustable camshaft sprocket (the small one driven by the chain), will the old one need to be heated in order to come off? And the new one too? Or is it just a matter of pulling off the old/pressing on the new?
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
  • jade
    • Jan 2005
    • 1811
    Originally posted by dkw_dude
    Hi
    Yes, heat and a puller.... to install, Cam in freezer and heat pulley press on
    RS 2 580HP
    • x6rs
      • Dec 2010
      • 134
      Use loctite aswell! Seen a sprocket trying to wander out at grind the valvecover.
      • dkw_dude
        • 555
        • Country: Norway
        Thanks for the advice. I read somewhere that loctite was not necessary, the guy just tightened the bolts tightly and it did not come loose.
        Leif-Helge
        • jade
          • Jan 2005
          • 1811
          Better with loctite, also better not to use normal hex head bolts as they stick out to far, I changed mine for some flatter ones raised round head
          RS 2 580HP
          • orignalS60
            • Mar 2015
            • 792
            • Home: Croatia Current: United States
            You don't even need a torch. Just
            a hydraulic press or a puller and they'll
            come right off.
