Hello all!
Valve 077 103 175B - the one that stops oil running back from the head to the sump when engine swithced off. Is there a torque figure published anywhere for this item?
I've seen the thread and borrowed the picture from quattroworld. Crushing it with ARP main bolts is not an issue as i'm using new factory bolts, i just wanted to know whether there is a figure so i don't go overboard and distort while tightening? (the valve body is quite a light duty)
Many thanks!
Many thanks!
