The C4 AANs came with one of two styles of viscous fan bearings. The UrS6s tended to come with a press in bearing and flange assembly. The PN was 046115136 for VINs SN030352 and beyond. 046115136 is now NLA. I am thinking that it might be possible to cut open the non-flange end of the bearing housing and press out the bearing or bearings and then replace the bearings with a new bearing (or bearings).
More info: http://forums.quattroworld.com/s4s6/msgs/33332.phtml
Step 1 is to find out what is inside the press-in bearing housing. I have an UrS4 with older style bolt-in bearing and therefore can not investigate the later bearing.
Therefore, I am looking for a C4 S6 volunteer who happens to have an old newer style bearing that they are willing to cut open, measure and photograph in aid of finding a solution to this developing issue.
What is in side this?
