hello all,
Frustratingly I have hit a ridiculous snag which has put the brakes on getting my engine rebuild under way. I finished checking all my bearing running clearances and gapped the new piston rings but came to press in my new con-rod bolts and found them to be really very tight.
I understand there should be a certain amount of interference to hold them in place in the rod but there shouldn't be any interference with the cap, I've got so much it struggles past the threaded section and doesn't sit down on the rod without doing the nuts up!
I pressed the new bolts out again and found that the original bolts were 12.9mm on the shoulder which locates the bearing cap and the new bolt was 13.0mm.
I got the Febi bolt 02126 as this is widely available i thought i can't possibly go wrong - they wouldn't be so widespread if they didn't fit would they? well...
OEM number appears to be 026 105 425A / 048 105 425A and both point back to Febi 02126.
Other than fitting ARP, anyone any thoughts or fixes having been there done that? I don't really want to splash out on ARP as the rebuild job is a standard 7A and though I get the ARP benefit for high performance engines, mine has gone for well over 200,000miles with standard bolts and is fine so i don't see i will gain anything
cheers!
cheers!
