AEL diesel purge(flushing)
  • Joop
    • May 2015
    • 89
    Yesterday i tried to clean the fuel pump,injection noozles the fuel system with liquid molly with the method of second picture.
    I i disconnected the fuel filter,the feeding line and the returning line.
    During the flushing i was sooooo happy even at 3000 rpm there was no any smoke
    from the exhaust.
    The red line is the feeder,the green one is the returning. I also set a small spin filter to the returning line to prevent to push it back the same dirty.
    When the liquid molly was empty i load the fuel filter and the fuel pump with diesel to prevent that air goes to the system.
    I changed the fuel filter too but when i started the engine in normal mode i became upset it is still smoke in high rpm or in 2,3 shifting mode.
    I trust in i setted up the correctly the lines but there was no any dirty in the returning line the filter was almost new and clean.However the fuel filter was replaced 10 years ago.
    I don't understand why there was not any black smoke comes out when it was working from liquid molly
    Thank you for your help
  • AndyP
    • 6049
    It won't smoke when you're running the flush through as the engine is not under any load, plus the liquid moly will not burn like derv does.
    Whay colour is the smoke you're getting?
    • Joop
      • May 2015
      • 89
      Thank you for your reply.It is a black smoke.I don't know how can i reduce the smoke now.Maybe dissassebly the injector and clean the injector noozles invidually?
      • AndyP
        • 6049
        If it's black then that over fueling. I'd check the simple things first, like is your air filter clean? Do you have access to VCDS so you can check the readings off the MAF?
        • Pauliusb2
          • Dec 2014
          • 361
          Does your car have a chip?
          • Joop
            • May 2015
            • 89
            Hello,
            thank you all your answer i am working on to get a vcds to check the parameters.
            The car has not have chip
            • Joop
              • May 2015
              • 89
              It took me a while to get acces to vcds but now its ready to measure the values.What group should i check and where can i find the reference values?
