Hi
So im getting close to building my turbo "manifold"
I have a precision 6262 ceramic bearing turbo. I bought the turbo, injectors (630 cc siemens deka), wastegate (39mm precision), bov (tial recerculating) and a couple of other bits used (low mileage) from a lad who was runniing them on a 24v vr6 golf. He was running 1bar boost and making 450 whp. I have asked him if there was any boost creep issues and he said it held boost fine.
Now, am i right in thinking that if the gate can hold 1 bar of boost perfectly well it can hold more boost even easier... Or .. Will the increased flow of gas mean the gate will need to dump even more gas relative to the boost pressure (if i am making sense here)
I am just a little paranoid that 39mm is relatively small for a wastegate. And my engine is 2.8L and the turbo is medium-sized at least.
Id rather get a bigger gate now before building my manifold. I was also thinking of getting a second matching gate to be safe. I can then provision for this on the manifold.
What are your thoughts on the set up as is? Will there be any problems holding/controlling more than 1 bar of boost?
Thanks for any input.
I would rather save a bit of reworking later if it needs to be changed
Jason
Jason
