RS2 Exhaust manifold options
  • orsum
    • May 2010
    • 1213
    • Home: United Kingdom Current: South Africa
    Looking for an alternative RS2 exhaust manifold that is a straight bolt on and oil pipes in the same position.
    I have an original manifold but don't think I am going to use it, it has been welded.
    So I am looking for recommendation for a good solid manifold that fits stock position and stock connections to suit the original RS2 Turbo.
    Regards
    orsum
  • piotr
    • Jul 2012
    • 1470
    Maybe you could try Carsten?
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      Wagner is the obvious choice. I have this one, brand new, LS-Cartec made.
      http://www.ebay.com/itm/Turbokrummer...4AAOSwKtVWxdWt
      • orsum
        • May 2010
        • 1213
        I thought they stopped making them!!
        Are they good, anybody had issues? RichLV how long have you had yours fitted, did you have any issues?
        What about tubular
        orsum
          Some cast EM flow numbers
          Originally posted by orsum
          I thought they stopped making them!! Are they good, anybody had issues? RichLV how long have you had yours fitted, did you have any issues?
          What about tubular. orsum
          If you are staying with a K24-7000/7200/7400 series turbo, snag the Wagner RS2 EVO EM and be more than happy. It flows better than either the RS2 EM or the Sport Q EM. Tubular = pain unless you are going Holset, etc.
          Read this: http://forums.quattroworld.com/s4s6/msgs/80650.phtml
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            What about tubular
            orsum
            Have mine for around 3 months. No issues yet.
            Tubular is better if you want equal length headers.
            • orsum
              • May 2010
              • 1213
              Just do not wish to have cracking etc.
              SQ looks nice
              Looks like a direct fit from the pictures, is it??
              orsum
              • RichLV
                • Mar 2015
                • 872
                • Country: Latvia
                Use it properly and you will not have cracks. Don't stress it while it's cold and let it cool (idle) after a longer drive, and you should be just fine.
                  And make a good turbo brace....
                  • adam g
                    • Feb 2007
                    • 445
                    Do you have any images of a good turbo brace. Interested to see where you mounted it on an I5.
                    Sent from my D5803 using Tapatalk
