Air mass testing rs2
  • dobbin
    • Jan 2011
    • 164
    When testing my rs2 air mass meter engine running voltage between 1 and 3 pins should be between
    3 and 5 volts depending on the revs used but on mine it's only just going over 3 volts at 4000 rpm where as the copy Chinese one that's new shows 3.5 volts and climbs to that much quicker than the original unit . I'm trying to find out why the car won't full boost intermittent fault mrc says it's air mass meter
    But my original bosch unit has only done 4000 miles from new 2 years old now .
    Anyone else had this problem.
    I bought the copy one with the intension of fitting the rs4 sensor subject to anyone else saying it can be done
    G70 MAF testing
    G70 MAF Info:
    MAF testing worksheet:
    • vidar skotheim
      • Apr 2005
      • 566
      • Country: Norway
      The copys i have tested ( with wide band ) gives more fuel. same result as original s2 maf will give on a rs2 . Wil be to rich on normal driving .
      • Joop
        • May 2015
        • 89
        if you have acces to vag-com you can measure MAF values as describe in:
        block 003
        But i don't know the properly values for RS2
