7a - 20vt engine block exchangeable?
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    hi guys
    i wonder if you can use a 7a engine block with crank to replace a 20vt engine block?
    has a 7a also oil spray jets? te same bore size?
    i want to buy a 7a engine just for spare parts because they are cheaper and not difficult to find but i want to be sure.......
    i know that a 7a head need to be machined for the water manifold but i dont mind.
    TWINCHARGED power,zero lag
    AEM W/M injection
  • Thuppu
    • 4115
    Bore is 82,5mm. No holes for timing belt tensioner. Other wise they are quite the same.
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      thanks thomas,about the holes for timing belt tensioner,is the place on the block te same where you can make some holes in?
      i forgot that de 7a 20v a 2.3 was,thats why bigger bore size
      i suppose the crank will fit? and what about the oil jets?
      AEM W/M injection
      • simon20vq
        • Dec 2010
        • 1379
        Crank the same and oil squiter's are there as well.
        • Thuppu
          • 4115
          Yes crank is the same, and oil squirters are there. Sure you can do the holes, but I'm not sure how thick the wall is, if it pierce to the water space..? (I will put studs on my diesel block for the tensioner, sealing them with some hydraulic sealant/glue)
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            You will pierce the water jacket. Had this on the old 3B which dudes tried to make into an AAN by drilling holes for the tensioner. Surprise, surprise - coolant starts to flow vividly when you take off the tensioner.
            • Lange
              • Apr 2012
              • 41
              http://www.audi-quattro-highlights.c...Highlights.exe
              • Thuppu
                • 4115
                Thats why you wan't to use studs and nuts.
                • QuattroFever
                  • May 2006
                  • 1360
                  I have a really old rusty 5 cyl block here maybe 7a but can't see any part numbers on it?
                  Where can these/are they supposed to be to identify the block or is it just a case of looking at the block features?
                  Volcano ABY coupe
                  Ant
                  • simon20vq
                    • Dec 2010
                    • 1379
                    Measure the bore?
                    • etsola
                      • Feb 2015
                      • 285
                      I'm almost in the same situation. I have 2 x 7a engines (without the cams ) and am acquiring bits and parts for a build.
                      1) Can I, and should I use the same head/block 7a combination add my goodies and swap it ? (i.e. are pistons, rods and crank all capable/same as 3b ?)
                      2) Just use the head, add the goodies, and bolt it on the 3b block ?
                      -Assuming I have the head machined for the water manifold before and that I have a 3b base (dizzy and no tensioner)
                      3) Other recommended options ?
                      • diesel des
                        • 3896
                        7a has high comp pistons.
                          7A is interchangeable with the 3B block except for the bore
