I am doing research for a potential project later in the year where I intend to do as much of the work as possible. I accept that doing this sort of thing could cost around £5k in parts alone but I don't want to spend money unnecessarily - such as replacing engine parts or transmission parts that are capable of handling the increase in power and torque.
The engine in question is a 2.3 20v VR5 to which I intend to add a K04 or something similar to get B5 S4 levels of power and torque, so not going nuts but still from what I've found out so far some intrenals will have to be changed. I know it's been done before as I've found some videos and forum posts from various vw forums etc. on specifically the VR5 being turbocharged, though no useful technical info from which I can learn and make decisions. Annoyingly there seems a lot more info and support (in terms of complete turbo kits etc) for the VR6.
I'm getting conflicting info on things like the pistons, rods and cams. From what I've read/watched so far this is my understanding of said items:
I've found quite a few VR6 turbo kits online as a reference for what requires modification or replacement but have thus far found no examples with new camshafts and some that don't offer new rods. This VR5 turbo kit offers forged rods as an option and a spacer plate, so standard pistons, and claims 550hp is possible - though I don't know the credibility of the company and their products... I have even seen an MX-5 turbo conversion where power is claimed to have been doubled, with a 'safe' map with no risk of detonation etc., but with completely standard internals!
I have sent off an enquiry to turbodynamics.co.uk as they seem to have the knowledge I need on this type of project - i.e. turbocharging an engine that was never offered in turbo format from the manufacturer - though I have had no response. I was thinking AutoMark would be a good place to go to get the thing mapped and I may ask if they have any pointers for engine prep. Anyone else got any suggestions on who to ask or even experience of their own that will help me?
If you're going to tell me "don't bother, you'll spend thousands and thousands" I don't mind so long as you can give me good reasons that I can consider
If you're going to tell me "just buy an S4" please modify that to "just buy a Legacy GT-B" as I still intend to leave the UK for NZ
......Forever!
- Pistons - Smaller pistons required to alter the compression ratio, though the same can be achieved with a spacer plate in between the head and the block. I would go with pistons instead of a spacer plate all day long as it seems an inelegant way of doing it. Are forged pistons required for strength reasons too? Remember I'm looking for about 100bhp increase and somewhere over 100 lb/ft increase at whatever boost would be needed to provide that from a K04 or similar.
- Rods - As far as I can tell only needed if you're increasing power/torque/boost to very high levels to provide extra strength. But would they need changing from standard the moment you add any form of turocharging?
- Cams - Need replacing with custom made ones to alter valve overlap and stop boosted intake simply going back out the exhaust valve.
with alex
It'll be another skill I will have learned during the process.
