Hello!
I'm having troubles with my 7A engine.
Basicly, if it's cold, then it won't rev at all, just wants to die and if I hit full throttle, it'll start misfiring and spitting back...
Here's the video too I made today:
And if the engine has idling about 10 minutes, then it'll rev to 3000rpm and then the same symptoms, misfiring and spitting back.
I've done:
* New MAF
* New Bosch injectors
* New Fuel pressure regulator
* New fuel filter
* Checked the lambda with multimeter (steady 0.4v)
Engine belt is in correct position, idle is fine and starts good, won't matter if it's cold or hot. Spark plug wiring is ok too, didn't feel anything electric if I touched them while running. Exhaust gases smell very rich, spark plugs are black, though everything related to mixture adjustment components are okay. Fuel pressure is 4bar (because of the a little bit bigger injectors than the original ones) when full throttle. No vacuum leaks also.
Also I can't read blink codes. Does it really have to be diode or a brake light will do?
What should I do?
I've done:
* New MAF
* New fuel filter
What should I do?
. And when you check your lambda with multimiter, you should not disconnect it from the wiring, just pull rubber protection off and measure from the connector.
