RS2 Injectors direct replacement
  • M0KK4
    • May 2013
    • 10
    Hello everybody,
    i used the search but i can´t find any exact answer.
    i´ve done a Turbo Upgrade from SMS Revo to TTH 7200-420 Turbo ( RS2 Turbo + Modifications good for 400-420 HP )
    I´m running it on the old Software from the SMS Revo with about 330 HP.
    Works fine so far.
    But after the Quattrolegende Meeting two weeks ago my original RS2 Injectors make Problems.
    I´ve planned to Map it in winter.
    400+ HP is the target
    And here´s my question.
    What Injectors can i run instead of the RS2 ? 0280150984
    I don´t want to spend 700€ for new ones and i wont take used ones
    My options
    The Bosch 440 0280155968
    The Bosch 470 0280156280
    Both EV6 .
    I know they fit mechanically
    but can i put them in and drive the car like the original RS2 Injectors or do i need to remap it ?
    I Hope you can help me .
    Best Regards Patrick
    Some info from Stan Weiss's Fuel Injector Data base:
    Part Number lbs/hr cc /min grams /min PSI BARS lbs/hr cc /min 80% 95% Feed Impedance Application n-H
    0-280-150-984 32.92 346 248.9 - - - - 50.6 60.1 EV1 High Porsche
    0-280-155-968 29.5 310 223 43.5 3.0 29.5 310 45.4 53.9 EV6 High - -
    0-280-156-280 37.9 398.3 286.5 43.5 3.0 37.9 398.3 58.3 69.2 EV6 High - -
    REFERENCE: http://users.erols.com/srweiss/tableifc.htm (use Ctrl F to key in on 984, 968, 280 etc)
    • M0KK4
      • May 2013
      • 10
      Hello,
      After some mails with L-Speed i decided to buy the 0-280-156-280 injectors.
      today i put them in and the engine runs fine with them, less Power because the air/fuel Ratio is not correct ( too much fuel) but for the new turbo i need a new map so it can be programmed with the new injecorts.
