Hi Everybody
I have an urS6 that seemed to have a tendency to leak a little water into the oil...but only when boosting, not under normal driving...
So I took the head off and had it pressure tested and the engineering company came back and said there is a crack between the spark plug and valve that causes the leaking...they found that with the initial pressure test nothing leaked, but after a "hot" pressure test was done it leaked.
Obviously I now try any source a replacement head (AAN or 7A) but it seems that all good heads has gone to a secret island where nobody will find them.
When asking the engineering guy about welding up the crack they seemed hesitant. According to them this rarely works, or works in the long term...
Is welding up the crack out of the question and/or as futile as it is made out to be?
Any comments or advise would be appreciated, thanks.
