Hi folks, I'm doing an engine swap into a VW T4 and wondering how critical the number of teeth on the ring gear is?
I know that the ring gear on the AAN URS6 flex plate has 135 teeth but I'm not sure that I can get a flywheel with this number of teeth for the T4 gearbox flywheel.
Will this matter or can I get away with a lesser number of teeth?
Thanks in advance
Shaun
Thanks in advance
Shaun
