AAN piston to bore clearance.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    Just finsished checking the AAN block.i used the dial bore gauge
    Checking diagonally from top and bottom of the cylinders.
    All 5 cylinders are all within permisssible tolerance 81.03-81.04mm
    (Stock bore 81.00-81.01).maximum out of round is 0.01mm and
    Taper is 0.005mm.anyway the block will need to send out for a honing
    Service.i searched on the google and found normally the honing
    will take out 0.0003"(0.075mm) of material.In other words,
    After honing job the cylinder bores will be 81.11mm.i
    Dont know if bore will be too excessive enalarged and caused
    The pistons slapped? The 1st oversized bore is 81.26mm.
    i'm not going to go for oversized pistons besides,if necessary.
    TIA.
    one of a few I5 from Asia.
  • diesel des
    • 3896
    I always like a new clean bore when doing a engine build. Fcp do nice wossner style own brand pistons at a good price. Wossner and their version of them run tight clearances and give no slap.
      Do you use a torque plate (head substitute) when doing this?
      • diesel des
        • 3896
        No I personally don't. The bore is more likely to distort when heated as well as being under the tension of the head studs. Cylinder pressure also distorts the bore so I don't feel that just a torque plate is worth while.
        • Cordoba16vt
          • Apr 2014
          • 182
          • Country: Bulgaria
          My 345 000km then block was honed during overhaul - just changed rings ( new Mahle style ) , bearings, seals , etc + 7A head . Engine compression is good , when descending in 1st or 2nd gear you can feel good engine braking power. No smoke whatsoever , some excessive oil consumtion - 2 lt per 10 000 km , on RS2 turbo with a label clearly indicating it was made in 1994
          Prior to rebuild inspection there was clear signs of original honing present with some minor glazing halfway down the bore. Honing is 0.01mm anyway and if done properly is good for setting in the new piston rings .
          Anything up to 0.1mm between piston and cylinder will not make pistons slap or excessive oil consuption, due to bore/stroke ratio, piston design ( long skirts , etc...) , if built properly .
          All the best
          Ivan
          • orignalS60
            • Mar 2015
            • 792
            • Home: Croatia Current: United States
            @pop you can buy oversized rings from
            goetze. Then gap them appropriately for
            the added bore.
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              the added bore.
              Yeah,Normally when we went for oversized rings it means we also need oversized pistons IIRC?
              • orignalS60
                • Mar 2015
                • 792
                They are for stock pistons. They are 0.020"
                oversize. Bigger pistons run .5mm at a time.
                The oversize rings are for worn bores after
                refurbing them with a nice hone.
                If you want you could always buy some 81.5mm-82mm
                forged pistons so you'll have fresh bores with your
                pistons fitted to them.
                • orignalS60
                  • Mar 2015
                  • 792
                  Auto Parts for Your Vehicle at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
                  • orignalS60
                    • Mar 2015
                    • 792
                    ^^^Go under piston rings.
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      Thanks mate.
