Bosch f5dp0r still failing?
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    Hello
    Do they still fail?
    What about useing ngk pfr7b or 8
    Any other great plug to use on a 450 hp s2 aby?
    Around 1.8 2.0 bar boost? 99 vpower fuel
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    NGK BKR7EIX is the plug to use. 20 valves seem to be very happy with those.
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I used NGK BKR7EIX before, good plugs gapped to .6mm. However now I am using Denso IK22, I feel they are much better than the NGK. For your power level however maybe the NGK will not be strong enough.
      1996 S2 ABY Silver
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        Im aming for 500 in the end though
        What about going 8eix?
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          For 500 8EiX will be better than the 7EiX.
          1996 S2 ABY Silver
          • K Simmonds
            • Dec 2007
            • 7627
            I'm a fan of Denso PK22 PR8's, they perform very well, their quite expensive for a copper cored plug but seem more reliable than any other plug I've tried over the past couple of years in my RS2+ spec S2.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              I have never heard of these plugs before, maybe it is something I will try the next time I require a plug change
              1996 S2 ABY Silver
              • s2dk
                • Jul 2016
                • 507
                • Country: Denmark
                The denso one or ?
                • URSIMPO
                  • Jul 2008
                  • 431
                  NGK BKR7EIX is working well for me with just over 400 horsies. Can't define if there's any actual performance improvement, but certainly detriment to it either. Can sleep easy at night as well
                  • hunker7
                    • Mar 2014
                    • 3487
                    NGK for the win. BKR8EIX in mine, and not a single hiccup.
                    '93 Audi UrS4 Avant
                    '15 Audi A7 quattro 3.0 TDI
                    • s2dk
                      • Jul 2016
                      • 507
                      • Country: Denmark
                      What hp power lvl do u run on ur 8's
                      • s2dk
                        • Jul 2016
                        • 507
                        • Country: Denmark
                        What hp lvl do you run on 8eix?
                        • hunker7
                          • Mar 2014
                          • 3487
                          Mine is mere 260, but had issues with Bosch and LPG setup, was misfiring at higher revs, used NGK and problems solved.
                          EDIT: These were recommended by someone who's car is running 450HP I think.
                          '93 Audi UrS4 Avant
                          • s2dk
                            • Jul 2016
                            • 507
                            • Country: Denmark
                            Im running 350-400 atm
                            Dont know but running 1.45 bar and are using a set of bkr7e that are old
                            First im trying a new set with gab 0.6 mm
                            Later i will go eix 7 or 8 when map is done
                            Running a safe map atm
                            • hunker7
                              • Mar 2014
                              • 3487
                              Just remember don't try and gap 7's or 8's
                              '93 Audi UrS4 Avant
