Best place for oil catch can sump return?-opinions
  • orignalS60
    • Mar 2015
    • 792
    • Home: Croatia Current: United States
    As the title states I'm trying to build a catch
    with a return line vs. a drain. I would like for
    it to return the oil back into my sump. My question
    is where would be the best place to weld a fitting
    for the return line. Looking for opinions on whether
    it be on the oil pan or somewhere else. TIA
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    i connect my return with the sump plug
    TWINCHARGED power,zero lag
    AEM W/M injection
    • diesel des
      • 3896
      Jp reckons you need it at or near the front of the sump. My urs4 is connected back to the sump plug.
      • ringbearer
        • Sep 2011
        • 176
        034 makes an adapter that goes between the turbo oil drain and the block. You could fab one or try your luck and see if they still have or make it.
        • mcandmar
          • Apr 2004
          • 5118
          Do you collect enough oil that you need to return to sump? I would rather not as its going to be mixed with a lot of water vapor from cold starts.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • diesel des
            • 3896
            The 034 one is crap. Its for like 5mm hose. You need at least 12mm.
            • diesel des
              • 3896
              You can pump out a pint of clean oil after a few rash starts and a hard drive. Makes sense to get it back into the sump. Any water vapour will boil off. Not an issue unless you live someplace real cold.
              • mcandmar
                • Apr 2004
                • 5118
                Yikes, i must drive like a granny in that case
                I installed a catch tank about 1k miles ago and its caught **** all. Maybe the added breather hose routing stops the oil before it gets that far.
                • orignalS60
                  • Mar 2015
                  • 792
                  @ringbearer, thanks for the idea. I'll
                  rig up a -an Y fitting with my turbo return
                  lines. They're steel braided anyways.
                  • orignalS60
                    • Mar 2015
                    • 792
                    For those with it at the plug you guys don't
                    have problems with the oil sloshing back up
                    the hose?
                    • V6quattro
                      • Sep 2008
                      • 949
                      How much oil does your catch can collect? I only see a little bit white fluid and some crap. No need to drain back if you're setup is right I think.
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        i have made a return comming from my mann provent catch can but actually i have never had oil return needed because of a good crankcase ventilation
                        and no,never had oil comming from the sump in the catch can but it is placed as high as the brake master cilinder
                        AEM W/M injection
                        • diesel des
                          • 3896
                          the hose?
                          I use a mann check valve.
                          • andy10v
                            • 5996
                            Taken from the normal breathers mine collected nothing but water vapour in normal road use, however on track you could fill it in a few laps, hence alternative breather locations or a return drain.
                            Sold ABY-stock
                            • orignalS60
                              • Mar 2015
                              • 792
                              After driving various modded cars
                              I've owned with catch cans I experienced
                              the catch can or tank will full up over
                              time with oil and yes vapor. I would always
                              have to unplug the drain at the bottom of
                              catch can and catch the oil & vapor into
                              cup oil container. Oil does build up especially
                              if you drive your car hard.
