Thermostat rage!
  • Efini
    • 154
    • Home: United Kingdom Current: United States
    Thermostat rage!
    Paying good money for phone number to the engineer who placed the thermostat on theese engines..
    I've been trying to get at it for three days now. The whole front is dismantled and so far I've only barely seen the thermostat housing.
    I'm towing it to the dealer tomorrow...
  • porkkis
    • 1994
    Naah, don't give up.
    All you need is to unbolt the middle section of the lock carrier and take the PAS pump belt out and unbolt the pump and raise it as much as the hoses let you. There it is.
    • Efini
      • 154
      Thanks, but I have allready unbolted the pumb and removed the bracket and belt. Still can only move it about 3cm upwards. I can see one of the thermostat bolts, but I'm nowhere near reaching it with any tools...
      I want my Mazda Rx-7 back.. It only took me about 2 minutes to change it's thermostat, and that was including coolant refill.
      • porkkis
        • 1994
        Perhaps it's a bit different on DF engines then. In 3B I was able to raise the pump so that it sat between the IM and radiator, or actually a bit above.
        • audiman
          • 4827
          It isnt much fun, but you can do it by pulling the pump out of the way.
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
            I found this very easy with the radiator out. good access, i followed the guide from MikeS2
            I didn't disconnect the PAS pipe as it's not neccessary.
            • Efini
              • 154
              I wish I didn't have the AC.. If I remove the radiator, I will have to remove the AC-condenser too. And that is serious work.
              I've been trying to get the PAS pump out of the way for an hour now, but it's too tight between the AC condenser and the intake manifold.
              Can anyone tell me hove many bolts there are in the thermostat housing?
              I'm selling the car as soon as I get this sorted. Never had more problems with a car, and the way it's built it's a bitch to work on..
              • Efini
                • 154
                Finally got my thermostat housing of! After using some muscle i got the pump out of the way, thanks for the tip guys.
                But... I'm not able to remove the old thermostat, it just won't move. I've tried pulling it out, prying it out and even hitting it with a hammer!
                This car is just FANTASTIC!
                • porkkis
                  • 1994
                  Hit it more, twist it with a screw driver etc. It will come out. You can't break anything else than the old stat.
                  • Efini
                    • 154
                    Thanks Porkkis! The twisting did the trick.
                    Too bad the old thermostat looks rather okay, might have to find another source of my low-temp problem.
                    • AAH!
                      • 497
                      • Home: United Kingdom Current: Bhutan
                      Multi Function Temperature Switch (MFTS)?
                      formally RS2 +
                      • Efini
                        • 154
                        Where can I find that?
                        • AAH!
                          • 497
                          Picture of the MFTS (marked "B")
                          Picture is from this thread: "Just bought an S2 - Temperature question"
                          There may be other answers for you here.
                          Not so relevant but also talks about MFTS
                          Also do a search on MFTS
                          HTH
                          Angus
                          formally RS2 +
                          • Efini
                            • 154
                            And the MFTS is reletad to boostproblems too?? Bacause I sure have that too.
                            Very interresting reading, thanks a lot Angus!
                            Btw.. The "selling-my-car-when-done-part" was just temporary insanity, now it's getting more interresting than irritating.
                            • martinjs
                              • 3205
                              Yes, the ecu can reduce boost if the MFTS is toast.
                              Just try disconnecting it to test.
