VCDS Reading Modules
  • LGK6D
    • Oct 2011
    • 288
    Hi All,
    I've got a new Rosstech wire and the 2x2 adapter with the latest version of VCDS software. It connects to the RS2 by using the 8C engine code with no problems, but it will only see the ABS and Airbag, all of the other control modules say not found. What am I doing wrong?
    Thanks
    David
  • M_GORDON
    • Oct 2008
    • 1295
    • Home: Isle of Man Current: Vatican City State
    reg the wire
    But not much modules you can read on ours cars:
    motor
    ABS
    Airbag
    climatronic
    photobucket SUCKS
    • LGK6D
      • Oct 2011
      • 288
      It's the engine sensors I want to check and see if there are any fault codes. How do I go about doing that?
      • SteveH
        • 4460
        If there are any fault codes the ECU has stored, they will be readable via VCDS. Look under the engine tab. You can do some output tests via the engine option and also view measuring blocks and run some logs if needed. There's not a whole lot more supported on the S2.
        91 Modded 3B
        14 A6 Avant Black Edition
        • M_GORDON
          • Oct 2008
          • 1295
          Who is your serial number? Sure that is emptly because you haven't regist it.
          photobucket SUCKS
          • LGK6D
            • Oct 2011
            • 288
            I've just checked and it's all registered. It says control module not responding on the 3 engine tabs? Could it be because the car is re-mapped?
            • twoqu
              • Sep 2003
              • 3103
              Try it with the engine running.
              Not sure why it would not communicate just on ign unless the ecu is unpowered by either fuse blown or perhaps an aftermarket immoboliser.
              If the car starts then we have to assume that there is an issue with either the connection or the ecu/sw somehow.
              • SteveH
                • 4460
                Check the comm port settings. It won't be due to being remapped.
                91 Modded 3B
                • LGK6D
                  • Oct 2011
                  • 288
                  Tried it with the engine running, same story. What do you mean "check the comm port setting"?
                  • M_GORDON
                    • Oct 2008
                    • 1295
                    I don`t think that the problem be comm port. With a wrong config directly dosen`t work.
                    I know one aby if no one VagCom work on it. Regrettably.
                    photobucket SUCKS
                    • twoqu
                      • Sep 2003
                      • 3103
                      What interface are you using?
                      You can change the baud rate to see if that helps although I thought the reason for the label files was that it set everything up. Might as well read through the Ross tech manual to see if that helps any.
                      As the interface connects to other modules it implies that its an issue with perhaps the wiring. They used to recommend removing the other K wires from the common post, leaving just the ecu one connected.
                      Does it Autoscan?
                      • twoqu
                        • Sep 2003
                        • 3103
                        Just checked and you cannot change the baud rate on the latest versions!
                        When you checked the interface status did you get any short to ground warnings on the K line?
                        Some more info here:
                        • twoqu
                          • Sep 2003
                          • 3103
                          Bit frustrating but if you still have an old interface and the corresponding Vag Com or VCDS version you could verify that you can connect to the ecu assuming you have before. Then you would know that is the upgrade thats the issue rather than anything on the vehicle.
                          • SteveH
                            • 4460
                            Scrub that! If you can read anything on other modules it won't be the Comm port settings as your cable can communicate with the car and PC. I would read the Ross Tech manual.
                            91 Modded 3B
                            • Dynasty
                              • Jan 2015
                              • 79
                              • Country: Norway
                              Check wiring harness (check for continuity between K- and L- line socket (white) and ECU).
