For quite a while my 7A equipped coupe has been a real pig to start. Just cranks and cranks but doesn't fire, sometimes it does finally start but now it's not starting at all. I've recently (couple of months back) changed the dizzy cap, rotor arm and set of plugs and fitted a decent second hand isv. This hasn't really helped and when changing the isv I found a split hose (the one from the isv to inlet manifold) so I need to source one of them which will hopefully sort the rough running but I don't think it'll sort the starting issue. Any ideas anyone?
7A not starting
7a starting problems
Hiya bud. Yeah had the same sort of issues. Mine was quite expensive to sort out. Had unmetered air, crappy injectors and a hairline crack in the inlet manifold, oh and the M.A.F was sticking so overall wasnt good. Got it all sorted now but hope to god getting yours sorted doesnt cost you half as much as it did mine.Comment
I certainly hope it doesn't cost a bomb as hopefully about to buy our first house! So money will be a bit tight to say the least. When it's actually running it drives sweet apart from a high idle so I don't think there can be that much wrong... Famous last words!Comment
high idle, poor starting, I would immediately hazard a guess at an air leak.1993 URS4 Avant Emerald Green 350+bhp
Well I've done a few checks and made a temporary repair to the split hose and things are looking up, it now starts but idle isn't quite right, still a tad high and revs are slowish to drop back I'll check the maf and other hoses for splits ectComment
20v.org has some advice on maintaining the 7a. The ISV is a damper for sudden throttle changes, the engine should start AND idle with it electrically disconnected. Suggest you go throw the basic troubleshooting and don't discount weak spark due to a old/bad coil, old plug wires.Peter S
1990 ErsatzS2 - track toy
1991 Coupe Quattro
1991 Coupe Quattro
1995 S6 Sedan
1995 S6 WagonComment
