Hi, unforutnately my recently build stroker engine have problem with oil pump.
The inner gear grinded into metal backplate.
From beginning, its forged 2.5L build in AAT block with AAT oil pump. Pump was is slightly better conditon then from car“s standart ABY. Oil squirts aby, checked all 1bar opening.
Running in oil was "premium" mineral 15W40+bosch filter, after 300km lazy driving(just few times on spring pressure to 5-6000rpm), changed to Motul x8100 10w60+mahle oc47 filter and go for more load and ecu tune.
On both oil i see quite low oil pressure on hot idle, just above 1bar.
Cca 600km overall, just after dyno session(maxed RS2 setup, stock 7200 rev limit - toutched few times) engine have ZERO oil pressure after start, when i want leave to home.
Conrod bearing survived. Pump gear has just gridned to not allowable/workable clearance(cca 0.6-0.8mm) - not able to suck oil from pan.
The backplate was surfaced before final pump instalation, surface is slightly roughter then OEM, which has also some finishning. On another non audi engines, this kind surfaced oil pump backplate work ok.
Do anybody have any inputs what was wrong or what check before instalation of my second pump(ABY)? I probably not touch the backplate now and also engine is runned up, so only quality synthetic oil will be used.
thanks
thanks
