radiator fan running when cold?
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    hello
    my audi s2 aby avant from 95 is being weird and old audi like.
    today i noticed that when i startet the engine the radiator fan startet running?
    its not running when ign is off.
    it ran for som time with engine on but then it stops and follow the normal heat cycle?
    im thinking that the coolant fan switch is bad?
    or could i be wrong?
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    a little update.
    seem like the fan is only running if i turn the heater blower on inside the car? a/c has been removed and there is no a/c relay.
    fan stop when nr3 relay is removed. when relief relay is removed or when fuse nr 17 is removed?
    tryid to unplug sensors on the block one at a time but did not do anything
    tryid to remove plug from the fan switch but it keeps running hvem engine is on? no blown fuses in fuse box...
    any ideas?
    • vidar skotheim
      • Apr 2005
      • 566
      • Country: Norway
      You have to remove on wire behind the ac display ..
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        Okay do u know witch one ?
        Its just odd cuz the ac gas been removed for a long time and the fan did not start
        But now suddenly it does ��
        • VagOrBust
          • Feb 2010
          • 107
          • Home: Netherlands
          That could be due to the resistor pack going bad. There's a resistor pack in the circuit to the fan that is used for regulating the voltage (and so the speed) of the fan.
          When it goes bad, it short circuits internally and the fan starts to behave weird. For me, it would go off any more.
          On my left hand drive Audi it was on the left inside of the bumper.
          5 cilinder addict:
          1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
          1993 S2, 2.2 turbo, ABY, long term project.
          2006 Ford Fiesta 1.4 TDCI. Because reasons.
          • s2dk
            • Jul 2016
            • 507
            • Country: Denmark
            Do u got a part nr for it?
            • s2dk
              • Jul 2016
              • 507
              • Country: Denmark
              Wil try to test fan switch later today and check tje resistor pack
              And have a look at the a/c heater display
                Manual AC or climate control?
                • s2dk
                  • Jul 2016
                  • 507
                  • Country: Denmark
                  Its the climate one u know lile the older a4 with the nr display in one side and where and how much air in the other
                  Like this
                    OK then easiest way is find the T5g green 5 pin connector by the relay panel under the dash, and remove the brown/black wire from pin 2
                    • s2dk
                      • Jul 2016
                      • 507
                      • Country: Denmark
                      Isent it odd that it juat startet doing it now?
                      • s2dk
                        • Jul 2016
                        • 507
                        • Country: Denmark
                        It juatt startet oit of no were
                        Sp think there is a real problem somewere
                        But think the other thing should be done
                        • s2dk
                          • Jul 2016
                          • 507
                          • Country: Denmark
                          Whaat does the t5g goes to ?
                          • s2dk
                            • Jul 2016
                            • 507
                            • Country: Denmark
                            So error that did not do anything ��
                            • s2dk
                              • Jul 2016
                              • 507
                              • Country: Denmark
                              Sooo found out this today
                              If i pull the plug out of the clima unit then it stops running.
                              But it got some down side to it. When i turn on the light the light slowly goes out in the clima display and the outaide temp does not work...
                              The one error said did not work or maybe i did it wrong
