Freeze plug diameter
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    Hi folks!
    Wanted to ask, has anyone measured the diameter of the coolant plug in the block for turbo? I can't get my hands in there to measure without disassembling the whole left half. My coolant pressure pipe is kinda old and leaking. Want to fabricate something for it so that I could forget about the leaks there. New pipe is kinda costly - 110 euros from AT.
    Coolant plug:
    Leaking pipe:
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    So why not buy a new aftermarket plug as a blank for that job?
    There are two diameters there according to the catalog: 36,6 and 38mm. Both types of plugs are avaliable cheaper than 1 euro.
    PS: OEM 035103111B is not NLA and it costs about 17euros ordered in any normal parts store at us.
    • RichLV
      • Mar 2015
      • 872
      • Country: Latvia
      Perhaps I wasn't being clear enough. I need the pipe, not the plug.
      My idea is that I'll cut the rubber part of the pipe off, weld some more meat on it and just stick a hose on the pipe and on the plug. That's why I was asking about the diameter of the plug, so that I know what hose i'll need and how much to fatten the aluminium pipe.
      • SteveH
        • 4460
        Weld an -AN connector onto a plain 36.6 freeze plug and convert the rest to braided hose.
        91 Modded 3B
        14 A6 Avant Black Edition
        • mac2226
          • Jun 2008
          • 1289
          Or buy 1 from Andyp already welded up with -an fitment
          • AndyP
            • 6049
            I have one of these in stock if you want to convert to a nice AN fitting
            • RichLV
              • Mar 2015
              • 872
              • Country: Latvia
              Thanks! I'll think about how I want to do it. What is the plug replacement procedure?
