Help can i with an engine support bar???
    • 4754
    Gearbox has been removed today from the 2.8 30v to make it easier to remove the engine and roll it on a dolly through the house out to the back garden and workshop,it's just easier that way.
    The urgent part is i now want to drop the engine beneath the car and roll it out on a dolly from underneath for good reason. I can see the 2 engine mounts that bolt in through the C4 chassis legs. Question......Using an engine bar support can i just remove the bolts form each engine mounting and just drop the engine out underneath.To me it looks like it will go but i will need to modify the engine bar to allow me to drop the engine out further than the bar will allow. Any ingenious ideas guys??
  • V6quattro
    • Sep 2008
    • 949
    Get a cheap engine hoist and sell it when you are done!
    1360kg/600Whp Avant 0-200km/h 9sec
      • 4754
      The ground just in front of the car has a 20" drop the reason why i want to drop the engine out underneath. Edit plus all the running gear is gone so no way to move car.
      • andy10v
        • 5996
        If you have a couple of different height objects to lower the engine on you can lower it onto a high object, wind the hooks back up, lengthen the straps or chains, then lower and repeat.
        Or grab a mate, tie a scaffold bar across the top of the engine and walk it out with a person on either side of the car?
        Sold ABY-stock
