I know that MC have from KG smaller screw thread. Do they differ with efficiency? To what power will suffice the moulding injections from MC, and to what will they these of KG?
What difference is between MC and KG injectors?
you may use from old mercedes 450/500(126 CHASSI) they have 8 injektors.... use only 5 of them,and plugg the others...or you may use from SAAB turbo,they use SOMETIME a K-jet with 6 injektors,with only one plugged....... if you opend the K-jet head,replace the SPRING inside the same way they are fitted!!!!!.... and you may use the mercedes head,with saab turbo or audi springs innside..... if the spring arent so stiff the head gives MORE petrol, good luck with the racing....
If you want to tune the 10v with Kjetronic fueling you need to get rid of Kjet.
2 choices IMHO Luminition from Dialynx (I have this on my WR) or go to www.motorgeek.com and talk to Javad about his 034EFI both systems are very effective at getting serious hp from the 10v turbo motor, reliably.Corey
01636 822288
Originally posted by CoreyIf you want to tune the 10v with Kjetronic fueling you need to get rid of Kjet.
