Hello all!
I was curious the other day as to what the fuel pressure was on my 7A. It always feels like it could go faster and having fiddled, checked and adjusted everything else i realised that in the 14 .5 years of ownership - i have never tested fuel pressure.
I got myself a fuel line adapter and gauge and set about fitting it this evening to see what i could see.
Results make interesting viewing.
Book say 3.8-4.2bar. (idle with vacuum then WOT no vacuum)
difference of 0.4bar.
holding pressure after 10 mins 3.2bar.
mine has a difference of 0.5bar which seems near enough to me but the running figures are 3.1 and 3.6bar.
I'm missing quite a lot of pressure here but the enrichment action seems to be working consistently, just further down the scale. I also checked the holding pressure and it dropped to 2 bar within a few mins.
The car has the 034 bosch injector kit on it which might explain a running difference from factory if the injectors allowed more fuel through but with the engine off, they shouldn't and don't let any fuel through (never have fuel wet plugs or hot restart problems)
Has anyone ever had, diagnosed and fixed fuel pressure problems which turned out to be the FPr? I was just wondering if it could fail and just give lower pressures overall despite still appearing to 'work'. I think it is the original FPr on the car, I've never changed it...
fuel lines were replaced a couple of years ago as they had succumbed to the rust problem. All kunifer pipe now and leak free.
) and swapped that in. It gave exactly the same readings +/- 0.1bar.
