Advise needed please!!
There is something wrong with my s4 !! Its lacking power and holding back. you can see in the video its slow ! its struggling to build boost peak is about 1.7bar. but then its dropping of towards the top of the rev range down too 1.bar . it also cuts the power for about half a second violently shaking the car which is a nightmare if you pulling out of a corner. tend to get snap over steer.. also if its holding back when you give it WOT it occasionally sends a naughty flame out the back with a large bang... ive had it 4 months and previously it was fast ! now its gold gtd fast
its basicly Rs2 spec turbo/injectors/ map/fuel pump.. there nothing obvious. no vac leaks or boost leaks. its just starting to get really annoying.
