Evening all,
As a lot of you are aware i have recently converted my 3B to RS2 spec with ABY ECU, TFSI coils etc, there have been many trials and tribulations along the way but one that is annoying me is the lack of full boost on both VStream and TS chips. Both are rated for 1.9 bar but i only seem to get 1.7 bar.
I'm starting to to run out of ideas for why i'm not quite getting full boost as i have no obvious leaks up to 2bar, F96 Altitude sensor has been tweaked to read correctly, timing is spot on, running 97ron which is the best i can get on the island, certainly never had any issues with it on the previous homefry. MAF and N75 are relatively new with very little miles on them, MFTS has ben unplugged which made no difference. G62 coolant sensor new, IAT sensor working ok.
About the only sensors which i haven't replaced are the knock sensor but have never got a code for them.
I have in the past had them off to inspect them and noticed the plastic outer casing to be cracked but since they never gave me any other i just fitted them back to the block.
However, i don't remember tightening them to a specific torque, rather just a good nip for the size of the bolt.
What effect would an under or over torque bolt have on boost? If in fact any? Perhaps clutching at straws with this one but got to rule them. I read somewhere that the timing is pulled but no sure about boost?
Not sure what my loss of 0.2 bar equates to in power but i'm sure i would notice the difference.
Any ideas?
Any ideas?
