Did a day at Silverstone yesterday in the coupe, first time on the circuit for me and it was excellent.
During the morning I'd be running pretty consistent and stable 130-135deg oil temps over around 20-25 minutes on track. As the day went on the oil seemed to be less temperature stable and would heat up faster and temperatures would climb steadily over a 15-20 minute session up towards 150deg.
I was keeping an eye on it and backed off to let it cool back down when it started to get up to 150deg. At the end of the day within around 3 laps I was having to back off at the oil temp would rocket to 150deg and oil pressure began become unstable to.
I called it a day at this point and on the drive home (motorway cruising) oil temp would sit at around 120deg whereas I normally expect to see around 100deg. Oil pressure was also 3.5bar not the usual 5 bar. Currently running 10w50 Fuchs Pro Race and have a 19row Mocal oil cooler in the aux rad position.
I assume the oil has been chemically altered by the heat cycling and its viscosity has changed - anyone have any technical information on this kind of thermal breakdown?
Wall to wall GT-Rs & 911s. Some interesting stuff too - a Huracán GT3 racer, 458 Challenge & an NSX Type R and a very lovey Evora GT4.
