Borg Warner EFR Vband flange issue.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    My EFR 7163 with Indy car style flange turned out the flange
    is way smaller than generic 2.25" Vband flange as you can
    see on the photo.
    So my plan is going to machine the outer lip of the vband flange off
    But not sure if the V band clamp is still useable on this.anyone BTDT?
    I'm going to run this efr7163 on RS2 evo 'EM.i'm going to fabricate
    The kkk flange and weld it with the short section pipe tube with V band
    Flange on another end.
    one of a few I5 from Asia.
  • volcano rs
    • Jun 2005
    • 2265
    it will work i did the same thing. i had same the issue with my efr turbo and turbosmart wastegate .
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      Thanks mate.just another 2 quick questions.
      1.Did you end up machining the outer lips off too?
      2.Did the 2,25" Vband clamp tighten and sit properly after(if) machined off?
      • Thuppu
        • 4115
        Sure you can machine off some material to get same diameter to the flanges. But you must do something to the gap between the flanges, seems that there is a inner lip on the turbo flange so you must machine a groove step to the mating flange. Easy to do with a lathe at the same time you machine off the radius.
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Thanks Thomas,it's the male Vband flange on the housing.i'm going to machine a groove on the inner flange(as a female).
          • diesel des
            • 3896
            I had a v band flange machined to fit the turbo. I then used a tial v band clamp that I cut a small amount of and welded. Works fine.
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              Ok just an update,i got the Vband flange today.machining the outer/inner lips off
              to be matched the male groove on the turbo inlet.The 2.25" V band clamp is fully
              locking on the V band ended nicely.the face is also seated properly.
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                i'm going to fabricate the K24 style flange with SS304.Can anyone tell me if the
                10mm thickness is flawlessly?I got the 10mm SS304 sheet laying around.
