Been searching but not found definitive answers...
What are the exact differences between 3B and ABY coolant hoses - I mean full standard set...?
I know that the hose on the rear of the block is 3mm larger diameter on the ABY... what else? (I realise ADU has slightly different routing)
The reason for the question, I want to buy a set of Roose Motorsport hoses, but their kits have a different number of hoses specified for 3B vs ABY (8 for 3B vs 10 for ABY)
If the 3mm difference to the block is the only difference, I will buy the ABY kit and a larger adaptor for fitting it (or just tighten the clamp more...)
FYI, currently have Samcos fitted...
