Holset HX35 Copressor Racing
  • ristokru
    • Oct 2016
    • 270
    Hi,
    i found very interesting turbo. It spools very low and thats what i am looking.
    But does it go to S2 and is it so good as they say?
    http://www.ebay.co.uk/itm/262693716696
    600bhp+ and full boost by 3500rpm is proven on 2ltrs using good twin scroll manifold setups. Full boost by 4000-4500 using single scroll manifold
  • SteveH
    • 4460
    It's been said on here that they are cheap chinese knock off's.
    91 Modded 3B
    14 A6 Avant Black Edition
    • ristokru
      • Oct 2016
      • 270
      Ok. Bad info to me. It looked so good turbo for S2 as it spoolt 3500rpm.
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        But wasent the 3500 spool on a twinscroll ? Then it might not be that when using a single scroll
        • Kiku
          • Aug 2010
          • 497
          With twinscroll you also need a proper manifold built for twinscroll turbo otherwise it wont work as it should.
          • Thuppu
            • 4115
            Twinscroll work just well. You just can't make a proper pulse manifold with 5 runners. Almost all Holset turbine housings are twinscroll and they have been proven working well on these engines with just singlescroll manifolds.
            With a proper twinscroll pulse manifold(4, 6cyl) you may ge some better spoolup though.
            • Kiku
              • Aug 2010
              • 497
              Jep, i ment the same by that, that the turbo will not spoolup so fast as they could.
              • Jelle..
                • Mar 2012
                • 52
                • Home: Netherlands
                And a twinscroll with a quickspool valve?
                Like this:
