Ok i know mine isn't an S2 it's S4 AAN engine, i have tried driving the car with the WGFV unplugged and plugged (disconnected the electrical connection), made no difference at all to the level of boost i was getting on the dash gauge 1.8bar. Any thoughts on what this means????
A faulty WGFV or ECU does not let the boost rise as you have another problem. Check the fault codes. Measure the resistance of the WGFV pins. Should be around 30 ohms.
